JMJ1
Aug 09, 2014Aspirant
Incomplete Frontview - reinstall firmware
Hi guys, New on the forum, but have run an NV+ v1 for few years, to date no problems. But here we go. Installed a new BT5 homehub router, and on next reboot get an incomplete view of Frontview. Trie...
Aug 09, 2014Guru - Experienced User
You can do an OS reinstall from the front panel (not sure if that is what you did or not). That will reset your admin password (to netgear1) and also set your IP configuration to automatic (dhcp). It won't hurt your data.
You can of course also do a factory reset from the front panel, which will destroy your data, and require you to rebuild the NAS from scratch.
Details on both procedures are here: http://www.downloads.netgear.com/files/ ... 6Dec11.pdf pages 23-24.
Did you log into the NAS shortly before the router swap? Just wondering if you are sure that the problem is related to the router change.
- Jul 15, 2018Retired_Member
