RationaleIT
Sep 18, 2017Follower
Incorrect Capacity for Time Machine on my RN2120 v2
I can't seem to find a solution anywhere, at least no posts with working links. The unit has about 8TB usable storage. I had 5GB reserved for a private Time Machine, which was nearly filled up, along...
Marty_M
Sep 25, 2017NETGEAR Employee Retired
Hello RationaleIT,
It does appear that you are missing out some space allotted for your private time machine. I would recommend to perform a Volume balance or Volume scrub and check if that would help with the concern. You may check this link for additional information.
Welcome to the community!
Marty_M
NETGEAR Community Team
