gunrunnerjohn
Mar 07, 2024Aspirant
Incorrect storage usage display
I have this bogus usage number for my currently empty Backup folder on the NAS. Unless my disks have suddenly become infinite capacity, I really doubt I'm using 16,777,216 terabytes of storage for a...
- Mar 11, 2024
The error I am seeing is
Mar 03 16:43:23 ReadyNAS snapperd[7075]: Snapper delete-config Mar 03 16:43:23 ReadyNAS snapperd[7075]: loading 214 failed Mar 03 16:43:23 ReadyNAS snapperd[7075]: delete subvolume failed, ioctl(BTRFS_IOC_SNAP_DESTROY) failed, errno:39 (Directory not empty) Mar 03 16:43:23 ReadyNAS snapperd[7075]: THROW: deleting btrfs snapshot failed Mar 03 16:43:23 ReadyNAS snapperd[7075]: THROW: deleting snapshot failed Mar 03 16:43:23 ReadyNAS snapperd[7075]: CAUGHT: deleting snapshot failedI'm not seeing the 214 snapshot in snapshot.log (no snapshots are listed there for the share).
There are things you could try using ssh, but given that small amount of data in the volume I think you'd be better off backing it up, doing a factory reset, and then setting up the NAS again.
Sandshark
Mar 07, 2024Sensei
If it's empty, the best thing to try first is just delete it and re-create it. If it's not entirely empty, you can create a new folder with a different name, move the contents, delete the old folder, and re-name the new one.
