Pescatore04
Aug 30, 2017Aspirant
Increase storage capacity of RN102
Hello Folks, I am hoping someone can confirm (oe even tried) what I read in the Software Manual V6.7. I want to increase storage capacity on an RN102 with 2X 1TB drives. Redundancy is not importan...
- Aug 31, 2017
Hello Pescatore04,
Switching to FlexRAID from XRAID will not delete data as long as there is no DESTROY VOLUME clicked and DESTROY word typed. However, it is important and we always strongly recommend to always have full backup of the data, after all, it is not wise to store important data to just one device.
I believe your first option is okay.
As for the second option, no it would not lose any data. You are performing volume expansion which is allowed on XRAID. It should be done one disk at a time.
Welcome to the community!
Sandshark
Sep 01, 2017Sensei
Option one won't work. Even switching to FlexRAID, you'll have a RAID array that wants a second drive added to restore the redundancy it once had. You would have had to switch to FlexRAID first to allow the second drive to be additional non-redundant space.
To get where you want to be, you'll need to copy off the data, do a factory default with just one drive installed, switch off XRAID, then install the second drive.
- Sep 02, 2016Retired_Member
