loco42
Oct 24, 2017Aspirant
increase swap partition
Hi All, I have upgraded from 4GB RAM to 16GB. I feel like I should increase the swap partition. What do you think, shall I and how can I do this? Especially using RAID-1 I'm not sure whether I shal...
- Oct 24, 2017
One option might be to create a swap file, and place that on the data volume (or even a dedicated SSD volume).
Not something I've tried, but it seems to me that it should work, and is probably more sustainable than repartitioning the drives (e.g., it can easily be put back in place if you ever need to do a factory reset).
Oct 24, 2017Guru - Experienced User
loco42
Yes this could be one approach. I'm not a 100% unix guru, so I did some research on this. I will also need to adjust the /etc/fstab. Won't this be overwritten once I do a firmware upgrade?
Talking about factory reset. What would happen if I do a factory reset having 16GB of RAM. Once starting up and installing from scratch would it adjust the swap partition correctly?
- StephenBOct 24, 2017Guru - Experienced User
It might be - something you'd need to test.
The ReadyNAS will recognize and use all the memory. I don't think the swap partition size depends on the memory installed - I believe it's always 1 GB.
