Reefergeezer
Oct 19, 2016Aspirant
Increasing disc capacity
Hi, I currently have 2 x 500GB discs in my Duo which have been working fine for a number of years. I now want to update the discs to increase storage capacity (and also just part of routine maintenan...
- Oct 28, 2016
Reefergeezer wrote:
I now have a 1 TB disk in bay 1 and a 500GB disk in bay 2 which i hope to replace tonight so both dsks will be 1TB each. Will it automatically allocate the full 1TB to the shares once the second disk is replaced?
When you replace the drive, the system will first sync the existing 500 GB volume. After that it should prompt for a reboot and expand to the full 1 TB.
Post back on how it goes.
Reefergeezer
Oct 28, 2016Aspirant
All done successfully - phew! :manhappy:
I didnt get a prompt for the reboot (maybe didn't wait long enough after resync?) so I rebooted manually after which I got the message saying first stage of expansion had succeeded and asking me to reboot again. Expansion then took another 10-15 mins so now all completed successfully.
Thanks guys for the help and advice.
FramerV
Oct 28, 2016NETGEAR Employee Retired
Hi Reefergeezer,
Thanks for the feedback.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
