alcester01
May 03, 2021Tutor
Increasing Primary NAS Capacity - Reusing disks in Backup NAS
Hi All, I use a RN214 as my 'primary' NAS and an old RNDP400U as my 'backup' at home. The Primary uses 4x3TB drives in a RAID5 configuration and the backup uses 4x2TB in an identical configur...
- May 03, 2021
my Primary is 75% full (running disks 5 years old) so my plan is to buy new 4TB drives for the Primary and reuse the 3TB disks in the Backup. This should keep me going for another 5 years.
An alternative is to get larger drives - that is generally more cost effective.
For instance, two 6 TB Ironwolf drives would have a price of ~$280, and would give you the same storage gain as four 4TB Ironwolf drives (costing about $410). It would also make future upgrades of the primary NAS less expensive (as you can gain another 3 TB by simply replacing one of the remaining 3 TB drives with a 6 TB one). The main issue here is that you'd only gain 1 TB of space on the Ultra (2x3TB+2x2TB).
I'd get four 6 TB drives for ~$560, and set up both NAS as 2x6TB+2x3TB. Though that is a bit more expensive, it would give you 12 TB in each NAS (~10.9 TiB) - letting you do full backups of the RN214 to the Ultra. Using mixed sizes requires XRAID (the default) on both NAS.
As an aside, WD Red Plus drives are also good choices. But avoid the WD Reds - they are SMR, and several folks here have had trouble with them. The newest WD Red Plus models in these sizes are the WD40EFZX and the WD60EFZX. You likely will also see the older WD40EFRX and WD60EFRX out there. But avoid the WD40EFAX and WD60EFAX - those are the SMR models.
alcester01 wrote:
My question is the best way to make the swap. I'm thinking that I will simply swap one 3TB drive for a new 4TB in the Primary, and swap one 2TB for the 'reused' 3TB in the Backup (and let both rebuild RAID) before repeating until all 4 drives are replaced. Can I do that without needing to format the reused 3TB drives?
I'd like to avoid taking the Primary off-line if possible - it is heavily used by the family all week.
I always recommend hot-swapping drives (removing and reinserting them with the NAS running). Then the NAS "sees" both the removal and the insertion, and doesn't have to figure out what changed.
I'd remove the partitions on the drives from the primary NAS that you are re-using before you hot-swap them. You can do that by connecting them to a Windows PC, and running the erase / write zeros test in the vendor tools. That would also test them, which might be a good idea given their age. But you should be able to just hot-swap them, and format them from the web ui.
Personally I always test drives in a Windows PC before putting them in the NAS. I run the full (extended) read test, followed by the full erase/write-zeros test. I have sometimes had drives pass one and not the other. Use Seatools for Seagate. For WD, you can use either the older Lifeguard utility or the new WD Digital Dashboard utility.
I'd also suggest have a fresh backup of all your files (at least the non-replacable ones). If one of your older drives fails during the upgrade, you will lose all the data on that NAS. There is no RAID protection during a resync, and the process does require either reading or writing every sector on every drive.
After testing, hot-swap the new drives in the primary, one at a time, and wait for the resync to complete. The second drive will resync twice, and the capacity won't increase until the second resync. If you go with 4x4TB, then the third and fourth drives will also resync twice.
On the older Ultra: If you go with the 2x6TB+2x3TB configuration idea, then you have to hot-swap the two 3 TB drives before you hot-swap the 6 TB ones. If you try to hot-swap them last, you'll end up with a smaller volume.
alcester01
Jun 01, 2021Tutor
StephenB,
Just wanted to update to say that I proceeded with your 4x6TB approach and now have 2x6TB + 2x3TB in both my Primary and Backup.
After ensuring I had a full backup of my irreplaceable files, I hot-swapped one drive at a time and allowed full resync before moving on to the next. Each resync took less than a day so the total process took 6 days as follows: -
1. Primary 3TB -> 6TB
2. Backup 2TB -> 3TB
3. Primary 3TB -> 6TB
4. Backup 2TB -> 3TB
5. Backup 2TB -> 6TB
6. Backup 2TB -> 6TB
I simply used the Web UI to format the 3TB 'repurposed' drives when I swapped them in and had no problems. The 'Format' took only seconds each time before the drive started to be consumed into the Resync process. The new 6TB drives were recognised immediately and no formatting was required.
FWIW I went with Seagate 6TB Ironwolf NAS drives (ST6000VN001) as in the UK at the moment they seemed to have the best price / TB for my needs.
Many Thanks for your help.
Jun 01, 2021Guru - Experienced User
Thanks for following up - I'm glad it all went smoothly.
