NASklr
Aug 15, 2014Aspirant
Initial setup of 102
Bought an RN102 to get my feet wet in NAS's. I haven't looked at a linux type system in ~25 years, and even then it was just crude file management. So far- Received RN102 Ordered two WD 1TB Reds (sh...
xeltros
Aug 15, 2014Apprentice
The 102 uses a flash to store the install image. Once you insert a disk and boot, the disk is wiped (3 partitions are created : one for the system, one for swap and one for data) then image is extracted to the system partition.
So if you want to poke around, you would need a SATA disk that you can erase (if it's not empty, use factory reset with the disk inserted).
You could also use a VM. http://apps.readynas.com/pages/?page_id=143
