industryiq
Dec 11, 2011Aspirant
Input/Output Error
Hi all, I have recently moved my data from an old 1100 to one with bigger HDDs. The newer one is running 4.1.8 and 4 x 2Gb drives in XRAID. My backups from a readynas share to the front USB port used...
industryiq
Thanks for the suggestion. Will try that and comment here. (A hub was not my first choice, as I thought it might break the association between disk-name and "front_usb_port" which is the target for the readynas backup).
