GeHe
Apr 11, 2012Aspirant
Install trouble
I just received my Duo V2. Turned it on with a WD Green 1.5 TB WD15EARS and found Corrupt Boot in the RAIDar program. Turned it off and removed the disk and booted again. Now it said No disks detected...
GeHe
I tried with both a WD15EARS and a WD15EADS with the same result. They are not on the HCL, but the 2TB model is. But I should be able to access setup without any drives in it, right?
