GeHe
Apr 11, 2012Aspirant
Install trouble
I just received my Duo V2. Turned it on with a WD Green 1.5 TB WD15EARS and found Corrupt Boot in the RAIDar program. Turned it off and removed the disk and booted again. Now it said No disks detected...
GeHe
Right. I found it in another post somewhere. Status as of now is that my disk seems to work. I can copy some files to it, but when I tried to transfer large amount of data, it said that I needed more space. Strange, since this is a 1.5TB disk. Entering the System-tab, when I click Volumes, no information appears. Any idea why this is happening? Is there any way of formating the disk now?
EDIT: Under the health tab, I can see "WDC WD15EADS-00P8B0 1397 GB", but it still won't accept large chunks of data? One file at a time is ok.
EDIT 2: Copying one file at a time was ok, until i had copied 5 or so movies. Then the disk was "full"
