GeHe
Apr 11, 2012Aspirant
Install trouble
I just received my Duo V2. Turned it on with a WD Green 1.5 TB WD15EARS and found Corrupt Boot in the RAIDar program. Turned it off and removed the disk and booted again. Now it said No disks detected...
GeHe
Apr 12, 2012Aspirant
WD doesn't seem to have a fw update for either of the drives. In the health tab, I cannot see any SMART errors, but "The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. media backup" is listed in the logs.
I then deleted the two shares, and tried to make a new one. Decided to call it "test", but this, apparently, was violating the naming rules as only alpha numericals, dollar sign, underscore and something else could be used in the names.
Rebooted and did a volume check on boot. Received this email shortly after:
"e2fsck 1.41.14 (22-Dec-2010)
fsck.ext4: No such file or directory while trying to open /dev/c/c
Possibly non-existent device?"
