ddougan
Jun 04, 2016Aspirant
Invalid OID
I have an NV+ running RAIDiator 4.1.14 [1.00a043]. I've attempted to add it to my SNMP monitoring which has built-in checks for the ReadyNAS; however, I get "Invalid OID" errors, so am assuming that ...
- Jun 15, 2016
The OIDs were incorrect in the service I am using to monitor - they appear to have been missing the last digit. I was able to identify the correct OIDs using snmpwalk.
Des
DaneA
Jun 08, 2016NETGEAR Employee Retired
Hi ddougan,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance. If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
ddougan
Jun 15, 2016Aspirant
Des
- DaneAJun 16, 2016NETGEAR Employee Retired
Hi ddougan,
I'm glad that you were able to identify the correct OIDs using snmpwalk. :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
