pmalkeme
Nov 03, 2012Aspirant
I/O errors on disk
hi, i have a readynas duo (original) and i've started to get notifications in the log of I/O errors... Access to the disk on channel (??) is producing I/O errors. Although the array is still redund...
pmalkeme
Nov 04, 2012Aspirant
here are the smart stats for the two drives
**** disk 1
SMART Attribute
Throughput Performance 0
Spin Up Time 10771
Start Stop Count 3016
Reallocated Sector Count 0
Seek Time Performance 0
Power On Hours 2421
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 7
Program Fail Cnt Total 10506789
G-Sense Error Rate 3
Power-Off Retract Count 0
Temperature Celsius 32
Reallocated Event Count 0
Current Pending Sector 2
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 7
Load Retry Count 0
Load Cycle Count 3017
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 166
Power glitches 0
Hard disk resets 17
Retries 17
Repaired sectors 0
**** disk 2
SMART Attribute
Spin Up Time 11427
Start Stop Count 3198
Power On Hours 2439
Spin Retry Count 0
Power Cycle Count 8
Program Fail Cnt Total 10512172
G-Sense Error Rate 1
Temperature Celsius 31
Current Pending Sector 0
Multi Zone Error Rate 0
Load Retry Count 0
Load Cycle Count 3198
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 4
Power glitches 0
Hard disk resets 17
Retries 0
Repaired sectors 0
**** disk 1
SMART Attribute
Spin Up Time 10771
Power On Hours 2421
Spin Retry Count 0
Power Cycle Count 7
Load Retry Count 0
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 166
Power glitches 0
Hard disk resets 17
Retries 17
Repaired sectors 0
**** disk 2
SMART Attribute
Spin Up Time 11427
Power On Hours 2439
Spin Retry Count 0
Power Cycle Count 8
Load Retry Count 0
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 4
Power glitches 0
Hard disk resets 17
Retries 0
Repaired sectors 0
