pmalkeme
Nov 03, 2012Aspirant
I/O errors on disk
hi, i have a readynas duo (original) and i've started to get notifications in the log of I/O errors... Access to the disk on channel (??) is producing I/O errors. Although the array is still redund...
Nov 04, 2012Guru - Experienced User
In the first drive, the "Current Pending Sector 2" indicates two failures on reading the disk. (That is similar to the reallocated sectors, but since it was on a read, the drive didn't reallocate).
The "hard disk resets" are more concerning - the "Retries 17" suggest to me that the first disk might be the cause.
You could open an on-line support request if you want Netgear Support to take a look.
