Kaleem
May 01, 2015Aspirant
IP Address Issues
Hi, I have the following set-up: ReadyNAS RND4000v2 Firmware: RAIDiator 5.3.10 4 x Seagate 3TB I've had it up and running for a few months, and only been using it now and then, mainly to t...
vandermerwe
May 01, 2015Master
Can you access the dashboard using raider?
In the manual you will find information about network settings:
http://www.readynas.com/download/docume ... Nov711.pdf
You can either set a static IP address in the readynas network settings or set a reserved address for the nas on your router or other dhcp server. if you set a static address, make sure it is not within the dhcp server range and that it conforms to the IP address format of other devices on your LAN.
As for the browser issue, try sorting out the IP address issue first, then clear the browser cache and try again.
A firmware upgrade will probably not help, but there is a newer firmware:
viewtopic.php?f=148&t=78065
Are there any error messages in your logs?
Are the disks all healthy ( check smart data)?
Do you have a backup?
