NJZGuy
Oct 24, 2015Aspirant
IP Address Stuck
I have a ReadyNAS Ultra 4 that has served me well over the years. I recently moved into a new apartment and had to change Internet Service Providersd as a result (From Cablevision/Optimum to Comcast/...
ifixidevices
Oct 24, 2015Luminary
Why don't you just shut the readynas unit off, plug it into a router that has DHCP enabled on it, let it assign it an IP and then connect your computer up to that same router (let it assign an IP on the computer) and then log into the unit based on the IP address it was given from the router.
Then I would assign it an IP address outside of the dhcp range and leave it static. I'm not sure what kind of network gear you have (perhaps you're using comcast's router) but I've always found it's better to use your own equipment than pay a monthly charge for the stuff that these big ISP's dole out.
That'd be my suggestion...
- NJZGuyOct 25, 2015Aspirant
Already tried that. The Comcast router does have DHCP enabled and has assigned IPs to all the the devices on my network except the Netgear ReadyNAS Ultra 4 (and yes, it is configured to automatically obtain its network settings from DHCP).
And as much as I would like to use my own router, that's not an option with Comcast.
- ifixidevicesOct 25, 2015Luminary
Do you have a different router you can temporarily use for this purpose?
Sounds like something isn't right with the comcast one. If you didn't care about what was on it then it'd be a different story but I'd try a different router. Some routers behave badly. I know with my router I can't get to my motorola modem stats page and it's a common problem for a certain model cisco router.
- StephenBOct 26, 2015Guru - Experienced User
If the NAS can't get a DHCP address, it fails over to 192.168.168.168. What status (and IP address) is RAIDar telling you?
FWIW, if the address is 192.168.0.100, then likely the default gateway would be 192.168.0.1. So that would be a bad IP address to set the laptop to. Maybe try 192.168.0.101, with a subnet mask of 255.255.255.0.
No need for a crossover cable btw.
BTW, did you mean to say you did an OS reinstall?
- NJZGuyOct 26, 2015Aspirant
A buddy lent me his old DLink and I hooked the NAS up to it and my laptop. RAIDAR found it immediately--it had been assigned 192.168.0.x (don't recall now) address besides the 192.168.0.100 that was still displaying on the LED. I backed all of my data up off the NAS just in case something went fubar after manually assigning an IP and I had to do a factory reset to wipe it and start fresh.One thing I did experiment with was to replace the four drive I had in there with two blank spares. I connected it to the Comcast router, launched RAIDAR and it of course treated them like new drives. Interestingly enough, the Comcast router had no problem assigning the NAS a 10.0.0.x address via DHCP--which displayed on the LED. Wouldn't do it for my original four drives though, no matter how many times I would do the non-destructive OS-Install from the Boot Menu. But I was able to assign and reserve a new static IP to the NAS to match what the Comcast router was happy with, and it's all working now.
Thanks for your help!
