ajnunes
Apr 25, 2021Follower
Is it possible to expand a ReadyNAS by connecting a second one to it
I have a ReadyNAS that is running out of storage. All bays are used with maximum drive capacity. Is it possible to add some kind of extension to the ReadyNAS? Or purchase a second one and connect the...
Apr 25, 2021Guru - Experienced User
The datasheet for the 524x hasn't been updated in a while. Although you might conclude that 10 TB is the largest size drive you can use, that is not the case. The datasheet just uses the biggest size that was available when it was published.
There is no known limit for the drive size in OS-6 ReadyNAS. The HCL currently includes 16 TB models, but I suspect that the 18 TB Red Pro, Ironwolf Pro, WD Gold, and Exos models will also work with no problem. Netgear isn't that fast at updating the HCL either.
You could add a USB drive, and share it (as its own volume). You can get another NAS of course, but there is no way to connect them together.
- SandsharkApr 26, 2021Sensei
To answer your specific questions:
I don't know if the 524x supports multi-drive eSATA units that use SATA port multipliers (like the discontinued EDA500) or not. Most of the newer ones don't, as it turned out to not work out very well (which is the likely reason the EDA500 was discontinued). I don't recommend you even think about it unless it's for archival data that's rarely accessed. Netgear has not added support for multi-drive volumes in a multi-drive USB unit. Any USB box with it's own internal RAID should be able to be used by the NAS; but the OS wouldn't see the drives separately, it would see one big USB drive. I tried that with a Drobo USB3 DAS unit just for kicks, and it worked. But Drobo has it's own issues and you really don't want to run one on a system where you can't use their management tool, so I don't recommend that specific brand, either, and any that require a tool that can't be run on a Linux system are probably best avoided.
You cannot hook two NAS together as master-slave. You can mount a share on one NAS on another, but that doesn't really meld them together and you're bucket-brigading the data from one through the other, so it makes little sense in most situations. Maybe if you don't use 10GB for your network and you connected two via the 10GBE ports, it would. But you'd still need direct network access to the second one.
I've not tried it, but you could probably create a volume on a multi-drive USB unit using Linux commands via SSH. But it would be best to try it on a system where there is no critical data, in case it brings it all crashing down. Expanding an existing volume to an external box would be a really bad idea, though probably also possible via SSH.
