robbie73
Apr 12, 2014Aspirant
Is it possible to use 102 as a caddy + ether and Usb?
Hi and thank you for reading. I did search a little but could see not an answer to this. After experimenting with the 102, I'm finding it a lot more work than I need for my simple requirement. I w...
Apr 12, 2014Guru - Experienced User
Any storage device that uses ethernet will have an operating system. In any event, the 102 has one, and cannot be used without it.
Of course you don't need to use the webui if you don't want to. And if you don't need to activate readycloud.
