robbie73
Apr 12, 2014Aspirant
Is it possible to use 102 as a caddy + ether and Usb?
Hi and thank you for reading. I did search a little but could see not an answer to this. After experimenting with the 102, I'm finding it a lot more work than I need for my simple requirement. I w...
InTheShires
Apr 15, 2014Tutor
StephenB wrote: I'm thinking that a windows server might not be that much easier anyway. User accounts, file permissions, sharing permissions show up there too.
Possibly right, I was going with the idea that a familiar UI might help but you are right.
