Jarkod
Aug 04, 2014Guide
Is ransomware attack on ReadyNAS possible?
Synology NAS servers are under attack of SynoLocker ransomware http://www.cso.com.au/article/551527/synolocker_demands_0_6_bitcoin_decrypt_synology_nas_devices/. Devices are encrypted and the owners a...
ukbobboy
Aug 06, 2014Luminary
Hi StephenB
Just want to clarify a couple of points with you:
You said:
You also said:
You see, if the technical boffins that designed and build the IT kits we use are unaware of or did not consider the emerging security threats that are out there and build in the necessary protection utilities then how can (home) users understand enough to protect themselves.
The main problem is that whenever anything computer enhanced is sold security of that equipment is a poor secondary afterthought.
UK Bob
You said:
That, without a doubt, is so very true but how many people understand that when they use a computer on the internet the risks they are taking? And even worse (or unknown), how can that risk be quantified?
nothing in life is risk-free
You also said:
Well, how can you manage something that is "unknown"?
what you really need to do is manage your risk
UK Bob
