johnw230873
May 25, 2015Aspirant
Is the way the shares work reversed for you as well
After buying a RN104 to me it appears the way you setup your storage seems reverse. In a normal system you set up a top level directory then you create structure bellow which can have multiple differ...
mdgm-ntgr
May 25, 2015NETGEAR Employee Retired
StephenB wrote:
I don't use iSCSI, but my understanding is that it is not a sharing protocol (that each LUN is intended to be mounted by only one client at a time).
You can mount it on e.g. a server and share it from there as John suggests. What is a problem is if you try to mount the same LUN on a few machines at once. It's similar to how you don't hook up e.g. a USB disk to two machines at the same time, but you can share the contents of the USB disk with other devices on your network.
