ErikRoss's avatar
ErikRoss
PLW1000-100PES wireless reversed mounting
I have read  information on product,  and I want buy this: Netgear PLW1000-100PES AC650 WiFi .
But before you buy it, I would have a question to ask
I want know, if  it's  possible connect the device inverted, not at the same mode of the page 7 of your link instruction, (Titled : install yours adapters).
http://www.downloads.netgear.com/files/GDC/PLW1000/PLW1000_FullIG_17Sept2015.pdf?cid=gwmng
But,  connect the wifi module to the router whit ehternet cable, and next module (whitout wifi) to the  other device (PS4 - Pc) whit cable.
PS: I have an example on pdf files if possible I can send it.
Thanks for attention.
  • Hi ErikRoss,
    The setup that you have presented should work.
  • Should work fine, but why would you want to?  Do you not have Wifi on your router, or is it poor coverage/quality?
    • ErikRoss's avatar
      ErikRoss
      my Ethernet line ends where there is WiFi coverage, in this way can extend the it.
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi ErikRoss,
        Which connection do you want to extend? Is it the wireless or wired connection? You can use the Powerline to extend wired connection as well as wireless connection.
