johnw230873
May 25, 2015Aspirant
Is the way the shares work reversed for you as well
After buying a RN104 to me it appears the way you setup your storage seems reverse. In a normal system you set up a top level directory then you create structure bellow which can have multiple differ...
May 26, 2015Guru - Experienced User
Ok. So the network permissions are controlled by NFS or CIFS, and the LUN file system (ext, ntfs, btrfs...) is controlling the file permissions.
mdgm wrote:
StephenB wrote:
I don't use iSCSI, but my understanding is that it is not a sharing protocol (that each LUN is intended to be mounted by only one client at a time).
You can mount it on e.g. a server and share it from there as John suggests. What is a problem is if you try to mount the same LUN on a few machines at once. It's similar to how you don't hook up e.g. a USB disk to two machines at the same time, but you can share the contents of the USB disk with other devices on your network.
That is of course the same as the ReadyNAS, except for the limitation of not exporting subfolders as their own shares.
