JohnWB
Jun 03, 2013Aspirant
Is there a way to share an APS UPS between a Duo and a PC
Does anyone know if there is a way to share my APC 550 UPS between my Duo and my PC so that they can both shutdown if the power fails.
I have tried connecting the lead from the UPS and a lead from the DUO to my DLinc powered USB hub but only the PC sees the UPS.
The Duo works fine if I connect the UPS lead directly to it
- vandermerweMaster
- JohnWBAspirantThanks for that, I will have a go once Iwork out how to change the script
- vandermerweMasterIt's not as difficult as it may seem. I had no knowledge of scripts when I installed it, the clarification notes in the script are good.
