Kev-H
Mar 14, 2017Aspirant
iScsi connections from ESXi hosts fail, then cannot reconnect.
ReadyNAS 31400 running Firmware 6.6.1 (latest). This firmware has been running for a while without problems. Xraid configuration 2x 4Tb disks and 2x 3Tb disks. Two Vmware Esxi 5.1 hosts access the ...
- Mar 15, 2017
Please see Skywalker's post
mdgm-ntgr
Mar 15, 2017NETGEAR Employee Retired
Kev-H
Mar 15, 2017Aspirant
Thank You.
I have conducted a test after reconfiguring the RN 31400 interfaces to use DHCP. Then to force a disconnect I rebooted the switch to which the Esxi Hosts and Netgear ReadyNAS are connected.
The Esxi hosts disconnected and then reconnected without problems.
