guitman
Jun 05, 2015Aspirant
iSCSI Corruption and chkdsk #25243902
I have a 4220 with 12TB. 10TB is an iSCSI LUN. Started having corruption issues with backups being stored on the LUN. Windows event viewer indicated drive corruption on the iSCSI device. Ran a chk...
mdgm-ntgr
Jun 05, 2015NETGEAR Employee Retired
How big is the LUN? Is it filling 90% of the volume or is there other data on the volume as well?
Is it thin/thick?
Do you recall on which firmware you created it?
You could try software such as Active File Recovery.
Do you have your iSCSI traffic going through it's own subnet and VLAN, separate to your other network traffic? If not, you definitely should consider this in future.
Is it thin/thick?
