t1000-forever
Feb 21, 2026Aspirant
Issue adding drive 4 to ReadyNAS nv+ v2
All I recently setup my ReadyNAS NV+ v2 from scratch with 3 3 TB Hitachi DK7SAD300 drives. The steps I followed and an issue I encountered are described in Best way to swap drives ReadyNAS nv+ ...
- Feb 28, 2026
Good news, I've just completed the factory reset.
What was awkward was that the setup from RAIDar took quite some time; at some point it had to perform a repair synchronising volume c across to disk 4. But after it completed 14 hrs later, I now see a net capacity of 8.1 TB.
Very pleased to see this, I immediately installed the ssh add-on to confirm the RAID volumes are all in good shape. And they are!
No idea why this was so difficult, but very pleased that it's now all working!
root@vanrun:~# mdadm --detail /dev/md0
/dev/md0:
Version : 1.2
Creation Time : Fri Feb 27 21:38:08 2026
Raid Level : raid1
Array Size : 4193268 (4.00 GiB 4.29 GB)
Used Dev Size : 4193268 (4.00 GiB 4.29 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Sat Feb 28 15:07:38 2026
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
UUID : 62d0bf22:792a8fc7:22dd1b9f:70d34a1d
Events : 18701
Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
1 8 17 1 active sync /dev/sdb1
2 8 33 2 active sync /dev/sdc1
3 8 49 3 active sync /dev/sdd1
root@vanrun:~# mdadm --detail /dev/md1
/dev/md1:
Version : 1.2
Creation Time : Fri Feb 27 21:38:09 2026
Raid Level : raid6
Array Size : 1048448 (1024.05 MiB 1073.61 MB)
Used Dev Size : 524224 (512.02 MiB 536.81 MB)
Raid Devices : 4
Total Devices : 4
Update Time : Sat Feb 28 15:03:34 2026
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
UUID : 843210da:82866fb2:20fe9997:a60abdf5
Events : 111
0 8 2 0 active sync /dev/sda2
1 8 18 1 active sync /dev/sdb2
2 8 34 2 active sync /dev/sdc2
3 8 50 3 active sync /dev/sdd2
root@vanrun:~# mdadm --detail /dev/md2
/dev/md2:
Version : 1.2
Raid Level : raid5
Array Size : 8776634112 (8370.05 GiB 8987.27 GB)
Used Dev Size : 2925544704 (2790.02 GiB 2995.76 GB)
Raid Devices : 4
Total Devices : 4
Update Time : Sat Feb 28 15:07:59 2026
State : active
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Chunk Size : 64K
UUID : 2eb52944:e890074d:fc59156f:99b14a04
Events : 905
0 8 3 0 active sync /dev/sda3
1 8 19 1 active sync /dev/sdb3
2 8 35 2 active sync /dev/sdc3
3 8 51 3 active sync /dev/sdd3
Feb 22, 2026Guru - Experienced User
t1000-forever wrote:The disk that has been hot added last loses its third partition somehow.
When you hot-add a disk, the NAS first formats it, and then creates the partitions, and finally resyncs. (This happens no matter how you add the new disk).
So what is happening here is that the NAS is choosing not to recreate the third partition after the format. The partition is not "getting lost". Usually that is a result of the NAS deciding that expanding the array is not possible.
I think your best option is to do a factory default with all disks in place, and see if you get different behavior. That might also resolve your issue with the OS partition RAID group. You would need to restore from backup afterwards. Not sure if that is what you meant by a "destructive install of the OS" or not.
Your option (b) would only have an effect if the OS was somehow corrupted - there is no indication that has happened. It shouldn't make any difference, but it is easy to try.
Option (a) is for a completely different NAS model. That said, manually creating the third partition and rebooting the NAS might work. If you do this on a PC, then make sure you power down the NAS before removing the drive, and leave it powered down until the disk is re-inserted.
