t1000-forever
Feb 21, 2026Aspirant
Issue adding drive 4 to ReadyNAS nv+ v2
All I recently setup my ReadyNAS NV+ v2 from scratch with 3 3 TB Hitachi DK7SAD300 drives. The steps I followed and an issue I encountered are described in Best way to swap drives ReadyNAS nv+ ...
- Feb 28, 2026
Good news, I've just completed the factory reset.
What was awkward was that the setup from RAIDar took quite some time; at some point it had to perform a repair synchronising volume c across to disk 4. But after it completed 14 hrs later, I now see a net capacity of 8.1 TB.
Very pleased to see this, I immediately installed the ssh add-on to confirm the RAID volumes are all in good shape. And they are!
No idea why this was so difficult, but very pleased that it's now all working!
root@vanrun:~# mdadm --detail /dev/md0
/dev/md0:
Version : 1.2
Creation Time : Fri Feb 27 21:38:08 2026
Raid Level : raid1
Array Size : 4193268 (4.00 GiB 4.29 GB)
Used Dev Size : 4193268 (4.00 GiB 4.29 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Sat Feb 28 15:07:38 2026
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
UUID : 62d0bf22:792a8fc7:22dd1b9f:70d34a1d
Events : 18701
Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
1 8 17 1 active sync /dev/sdb1
2 8 33 2 active sync /dev/sdc1
3 8 49 3 active sync /dev/sdd1
root@vanrun:~# mdadm --detail /dev/md1
/dev/md1:
Version : 1.2
Creation Time : Fri Feb 27 21:38:09 2026
Raid Level : raid6
Array Size : 1048448 (1024.05 MiB 1073.61 MB)
Used Dev Size : 524224 (512.02 MiB 536.81 MB)
Raid Devices : 4
Total Devices : 4
Update Time : Sat Feb 28 15:03:34 2026
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
UUID : 843210da:82866fb2:20fe9997:a60abdf5
Events : 111
0 8 2 0 active sync /dev/sda2
1 8 18 1 active sync /dev/sdb2
2 8 34 2 active sync /dev/sdc2
3 8 50 3 active sync /dev/sdd2
root@vanrun:~# mdadm --detail /dev/md2
/dev/md2:
Version : 1.2
Raid Level : raid5
Array Size : 8776634112 (8370.05 GiB 8987.27 GB)
Used Dev Size : 2925544704 (2790.02 GiB 2995.76 GB)
Raid Devices : 4
Total Devices : 4
Update Time : Sat Feb 28 15:07:59 2026
State : active
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Chunk Size : 64K
UUID : 2eb52944:e890074d:fc59156f:99b14a04
Events : 905
0 8 3 0 active sync /dev/sda3
1 8 19 1 active sync /dev/sdb3
2 8 35 2 active sync /dev/sdc3
3 8 51 3 active sync /dev/sdd3
t1000-forever
Feb 22, 2026Aspirant
I just found the original /var/log/frontview/raid_config_2026_01_31.log, this confirms the that volume md2 was originally setup with 3 drives/partitions.
What I also recall now is that the first time I added disk 4 afterwards, I did so after powering down the NAS (thinking that hot-add was not something that would be supported or would be a bad idea). Maybe this explains why the setup ended up where we are today?
***** RAID configuration log from 2026/01/31 *****
***** mdadm -D --scan -v *****
***** mdadm -D --scan -vv *****
***** mdconfig *****
Device : /dev/md0
Create Time : 1769872583
Update Time : 1769902702
RAID Level : 1
RAID Capacity : 4193268
Disk Size : 4193268
Chunk Size : 0
Disks : 3
RAID Disks : 3
Active Disks : 3
Working Disks : 3
Failed Disks : 0
Spare Disks : 0
State : 1 [ Clean ]
Disk Device RAID Disk Maj/Min Sectors State
0 /dev/sda1 0 8/ 1 8388608 6 [ Active Sync ]
1 /dev/sdb1 1 8/17 8388608 6 [ Active Sync ]
2 /dev/sdc1 2 8/33 8388608 6 [ Active Sync ]
Device : /dev/md1
Update Time : 1769902459
RAID Level : 1
RAID Capacity : 524276
Disk Size : 524276
Chunk Size : 0
Disks : 3
RAID Disks : 3
Active Disks : 3
Working Disks : 3
Failed Disks : 0
Spare Disks : 0
State : 1 [ Clean ]
0 /dev/sda2 0 8/ 2 1048576 6 [ Active Sync ]
1 /dev/sdb2 1 8/18 1048576 6 [ Active Sync ]
2 /dev/sdc2 2 8/34 1048576 6 [ Active Sync ]
Device : /dev/md2
Create Time : 1769872584
Update Time : 1769902675
RAID Level : 5
RAID Capacity : 0
Disk Size : 0
Chunk Size : 65536
Disks : 3
RAID Disks : 3
Active Disks : 2
Working Disks : 3
Failed Disks : 0
Spare Disks : 1
State : 1 [ Clean ]
0 /dev/sda3 0 8/ 3 4294967295 6 [ Active Sync ]
1 /dev/sdb3 1 8/19 4294967295 6 [ Active Sync ]
2 /dev/sdc3 2 8/35 4294967295 0 [ Standby ]
- StephenBFeb 22, 2026Guru - Experienced User
That doesn't explain the problem, the expansion should have worked. The NAS is supposed to detect a new disk from a cold start, and even if that didn't work properly the NAS still should have formatted again and expanded when you hot-added it later.
Starting over with all disks in place might (hopefully will) work properly.
