t1000-forever's avatar
Feb 21, 2026
Issue adding drive 4 to ReadyNAS nv+ v2
All   I recently setup my ReadyNAS NV+ v2 from scratch with 3  3 TB Hitachi DK7SAD300 drives. The steps I followed and an issue I encountered are described in Best way to swap drives ReadyNAS nv+ ...
  • t1000-forever's avatar
    Feb 28, 2026
    Good news, I've just completed the factory reset.
    What was awkward was that the setup from RAIDar took quite some time; at some point it had to perform a repair synchronising volume c across to disk 4. But after it completed 14 hrs later, I now see a net capacity of 8.1 TB.
    Very pleased to see this, I immediately installed the ssh add-on to confirm the RAID volumes are all in good shape. And they are!
    No idea why this was so difficult, but very pleased that it's now all working!
    root@vanrun:~# mdadm --detail /dev/md0
    /dev/md0:
    Version : 1.2
    Creation Time : Fri Feb 27 21:38:08 2026
    Raid Level : raid1
    Array Size : 4193268 (4.00 GiB 4.29 GB)
    Used Dev Size : 4193268 (4.00 GiB 4.29 GB)
    Raid Devices : 4
    Total Devices : 4
    Persistence : Superblock is persistent
    Update Time : Sat Feb 28 15:07:38 2026
    State : clean
    Active Devices : 4
    Working Devices : 4
    Failed Devices : 0
    Spare Devices : 0
    UUID : 62d0bf22:792a8fc7:22dd1b9f:70d34a1d
    Events : 18701
    Number Major Minor RaidDevice State
    0 8 1 0 active sync /dev/sda1
    1 8 17 1 active sync /dev/sdb1
    2 8 33 2 active sync /dev/sdc1
    3 8 49 3 active sync /dev/sdd1
    root@vanrun:~# mdadm --detail /dev/md1
    /dev/md1:
    Version : 1.2
    Creation Time : Fri Feb 27 21:38:09 2026
    Raid Level : raid6
    Array Size : 1048448 (1024.05 MiB 1073.61 MB)
    Used Dev Size : 524224 (512.02 MiB 536.81 MB)
    Raid Devices : 4
    Total Devices : 4
    Update Time : Sat Feb 28 15:03:34 2026
    State : clean
    Active Devices : 4
    Working Devices : 4
    Failed Devices : 0
    Spare Devices : 0
    Layout : left-symmetric
    Chunk Size : 64K
    UUID : 843210da:82866fb2:20fe9997:a60abdf5
    Events : 111
    0 8 2 0 active sync /dev/sda2
    1 8 18 1 active sync /dev/sdb2
    2 8 34 2 active sync /dev/sdc2
    3 8 50 3 active sync /dev/sdd2
    root@vanrun:~# mdadm --detail /dev/md2
    /dev/md2:
    Version : 1.2
    Raid Level : raid5
    Array Size : 8776634112 (8370.05 GiB 8987.27 GB)
    Used Dev Size : 2925544704 (2790.02 GiB 2995.76 GB)
    Raid Devices : 4
    Total Devices : 4
    Update Time : Sat Feb 28 15:07:59 2026
    State : active
    Active Devices : 4
    Working Devices : 4
    Failed Devices : 0
    Spare Devices : 0
    Chunk Size : 64K
    UUID : 2eb52944:e890074d:fc59156f:99b14a04
    Events : 905
    0 8 3 0 active sync /dev/sda3
    1 8 19 1 active sync /dev/sdb3
    2 8 35 2 active sync /dev/sdc3
    3 8 51 3 active sync /dev/sdd3
ProSupport for Business
