VolkerB's avatar
VolkerB
Issue with old user permissions and NFS
I recently migrated my RN214 to expose NFS shares instead of SMB (no Windows PCs anymore). Turned out that there was a UID collision, user "volker" was auto-assigned UID 100 which I didn't care too much back then.
Now, with NFS, UID 100 reflects to systemd-network on my local PC and the system would not let me change attributes, rsync was throwing erros similar to
sync: [generator] failed to set permissions on "/media/rn214-Media/somefile": Operation not permitted (1)
. So I created a new user "volker" on the RN214 (changing the existing UID was not possible) with UID 1000 which is the same on the local PC after first renaming the  existing user volker to "volker_old".
This new "volker" can read and write to files owned by "volker_old", copy them around and even delete them, but he can't get ownership of the existing file nor change permissions. Now I have numerous files owned by "volker_old" that I want to transfer to "volker".
So I figured running
find /data/Media -user volker_old -exec chown volker:users {} \;
in a shell on the RN214 would be an elegant solution to this, since
returned plenty of hits.
However, I get
chown: changing ownership of '/data/Media/somefile': Operation not permitted
errors, even as admin user belonging to the admin group. sudo does not exist and for su - I don't know the root password - if there is any.
Sure, I could just delete all the offending files and copy them over from a backup again, but this is about 5TB of data and will take an eternity.
Is there any way to resolve this ownership issue efficiently? Any help highly appreciated.
  • Here's what I did in a nutshell. Hope that helps.
    # SMB → NFS Migration (UID/GID aligned)
    * Problem: SMB does not reliably preserve timestamps → breaks rsync incremental backups
    * Solution: switch to NFS with consistent UID/GID
    # 0. Target State
    * volker → UID 1000
    * anja → UID 1001
    * shared group: users (GID 100 on NAS + client)
    * /data/Media → group RW (users)
    * /home → per-user ownership
    * NFS uses numeric IDs (must match!)
    # 1. NAS Setup (RN214)
    ## Users
    * Create:
    * volker_new (UID 1000)
    * anja_new (UID 1001)
    * Trigger home creation via SMB login once
    * Rename:
    * old → *_old
    * *_new → final names
    ## Fix ownership (/data/Media)
    * chown -R --from=100:100 1000:100 /data/Media
    * chown -R --from=101:100 1001:100 /data/Media
    * cleanup check:
    * find /data/Media -uid 100
    * find /data/Media -uid 101
    ## Fix permissions
    * chown -R :users /data/Media
    * chmod -R 2775 /data/Media
    ## /home migration (if needed)
    * move data or just:
    * chown -R 1000:100 /data/home/volker
    * chown -R 1001:100 /data/home/anja
    * ensure ~/.ssh:
    * chmod 700 ~/.ssh
    * chmod 600 ~/.ssh/authorized_keys
    ## Final cleanup
    * ensure no UID 100/101 left anywhere
    # 2. Client Setup
    ## Group
    * getent group users
    * if missing: sudo groupadd -g 100 users
    ## Add users
    * sudo usermod -aG users volker
    * sudo usermod -aG users anja
    * relog or newgrp users
    ## Install NFS + mount points
    * sudo apt install nfs-common
    * mkdir -p /media/rn214-Home
    * mkdir -p /media/rn214-Media
    # 3. NFS + fstab
    ## Enable on NAS
    * /home → NFS on
    * /data/Media → NFS on
    * RW, async, root_squash, NO all_squash
    ## /etc/fstab
    * rn214-volker:/home /media/rn214-Home nfs noauto,users,nfsvers=3 0 0
    * rn214-volker:/data/Media /media/rn214-Media nfs noauto,users,async,nfsvers=3 0 0
    * sudo systemctl daemon-reload
    # 4. Test
    * mount /media/rn214-Home
    * mount /media/rn214-Media
    ## Verify IDs (IMPORTANT)
    * ls -ln → must show:
    * 1000 100
    * 1001 100
    ## Write test
    * touch + delete file → must work without sudo
    # 5. rsync Migration (SMB → NFS)
    ## Copy
    * rsync -aHAX --dry-run --no-xattrs --no-g /source/ /dest/
    * rsync -aHAX --no-xattrs --no-g /source/ /dest/
    ## Verify
    * rsync --dry-run again
    * no output = perfect
    ## Finalize
    * rename:
    * user → user_old
    * user_new → user
    * test access
    * delete old only after verification
    # 6. Common Issues
    * UID 100/101 still exist
    → migration incomplete
    * permission denied
    → missing users group on client
    * root issues
    → check NO all_squash
    # 0. Target State
    * volker → UID 1000
    * anja → UID 1001
    ## Users
    * Create:
    * Rename:
    * old → *_old
    * cleanup check:
    ## Fix permissions
    * ensure ~/.ssh:
    * chmod 700 ~/.ssh
    ## Final cleanup
    # 2. Client Setup
    ## Group
    ## Add users
    # 3. NFS + fstab
    ## Enable on NAS
    * /home → NFS on
    ## /etc/fstab
    # 4. Test
    * 1000 100
    * 1001 100
    ## Write test
    ## Copy
    ## Verify
    ## Finalize
    * rename:
    * user → user_old
    * user_new → user
    * test access
    # 6. Common Issues
    * permission denied
    * root issues
    • StephenB's avatar
      FWIW, I've used rsync incremental backups with SMB for many years, and haven't found that to be broken.
      Note I am using the built-in rsync backup jobs, with both the source and destination being ReadyNAS.
  • StephenB's avatar
    Try logging in as root, and then using the NAS admin password.
    • VolkerB's avatar
      VolkerB
      StephenB​ : Thanks for the hint. Saved me a lot of hassle. I actually forgot that - after setting up SSH on the RN214 - I could either log in as admin or as root. root has all the necessary power for chown, so that made quick work of migrating UID 100 -> UID 1000 and adjusting the relevant files previously owned by UID 100.
      I'll post a summary of my journey as a reply to my enquiry, just in case someone else wants to move from SMB/cifs to NFS on a Netgear NAS because modtime got unreliable rendering incfremental rsync backups essentially useless.
  • schumaku's avatar
    schumaku
    VolkerB wrote:
    ...even as admin user belonging to the admin group. sudo does not exist and for su - I don't know the root password - if there is any.
    root is just a name, e.g. in /etc/passwd or some other authentication store. You could just as well call the account admin, and the OS itself won't care, ...
    Key is the UID/GID:0 - this is what -all- U**x'es Kernel and the code care about.
    There seems to be a long way ahead on your Linux learning curve. Not sure abandoning SMB in favour of NFS is a good idea therefore.
    Well possible, there is -much-more around of these files and folders than U**x file and folder permissions:
    Files can be secured through U**x file permissions - based on UID and GID - and through ACLs. Files with sticky bits, and files that are executable, require special security measures. What ever of these (visible and harder visible) does deny you desired action or actions.
    • VolkerB's avatar
      VolkerB
      Thanks for not being helpful at all. But perhaps you can shine your light on me to shorten the long and steep learning curve with some instructions how to change ownership of the files belonging to UID 100 to UID 1000 on the RN214 without copying over a large backup. Or alternatively how rsync -aHAX can update permissions of a NFS share when the target file belongs to a UID that does not match the user who runs rsync.
      In terms of abandoning SMB: Whether or not the idea was good is indeed arguable. The truth being that after an update of my Linux PC, modification time of files copied to the NAS via cp -p or rsync -t was suddently not preserved anymore and I got fed up with this lottery messing up any reasonable incremental backup.
      For details, head over to:
      https://bugs.launchpad.net/ubuntu/+source/linux/+bug/2007055
      https://community.netgear.com/discussions/readynas-use/modification-time-preservation-issue-using-smb-in-certain-configurations-with-re/2361349
      and make sure to leave a juicy comment there as well.
      • Sandshark's avatar
        Sandshark
        Sensei
        The best way to do it is via the GUI.  In the GUI, change the ownership of the share to the new user and then reset the permissions.  It has to be done separately on each share, but is still easier than doing so via SSH.  In general, it's best to use the GUI for things on a ReadyNAS unless the only way too do it is via SSH.  The NAS OS uses basic Debian for much of the user permissions, folder options, etc., but also has a database of some things.  Doing anything via SSH for which there is a separate database can create issues, and Netgear has never documented where those places might be.
ProSupport for Business
