swatkins89
Dec 15, 2022Aspirant
Issues after firmware upgrade RN4220X
Hello - I performed a firmware upgrade of my RN4220X rack mount unit earlier today via the admin portal and after a while it still isn't responding to ping. It attempted to upgrade to 6.10.8 from...
- Dec 16, 2022
This is fixed, performing the OS re-install through the boot menu fixed it and thankfully left all apps/data intact. However, it's still on the old firmware version, which I'm just going to leave it at. This unit is end of life, I'm going to work on migrating the data off of it and decommissioning the unit.
swatkins89
Dec 16, 2022Aspirant
I haven’t. The device console port is male and I only have usb to male console adapters/cables. I ordered a new one that’ll be here tonight.
Also, last night after giving more than 20 minutes to attempt the USB recovery I checked to see if where it was at (the blinking power, health, and UI lights) was actually the boot menu by rotating between the options. It was. I selected normal boot and pulled the flash drive and called it a night.
However, after rebooting the NAS is pulling an IP via DHCP now on port 2 but as of last night I couldn’t ping it. Didn’t try from the same network though, will try that today. Also, other ports on the NAS (I only tried port 1) didn’t seem to be working. It’s almost as if it reset network settings, even though I didn’t select that option.
At this point I would love to just be able to get into the device to extract the data, and then factory reset it. Haven’t had much success in doing that though. I’m hoping that I when I get into the office today I’ll have some success in being able to access shares, SSH, or at the very least the admin page.
swatkins89
