browerjs
Nov 22, 2016Apprentice
Issues with NV+
I have been using my NV+ for several years without issue, but the other day when trying to access it, I lost all access to my shares and it was reporting 0MB/0MB in frontview. On the NAS display, it...
- Nov 22, 2016
It does sound like a filling OS partition.
A Netgear Mod could offer courtesy help; other options include (paid) per-incident support from Netgear, and booting the system into tech support mode yourself, and useing telnet to access the system. That last option requires that you mount the OS partition manually.
Another approach is to connect the disks to a PC, and back up the remaining data. Then do a factory reset/rebuild the NAS. R-Linux for windows is one tool that I've heard will work. Or use a linux "live cd" and this procedure: http://home.bott.ca/webserver/?p=306
browerjs
I removed the password from each of my shares and I was able to connect. Not sure what the username was, but it must have been cached on my systems or something. Oh well, I think everything is back to normal now. Thanks so much for your help... Time to get a bigger external drive so I can back up my "unimportant" data just in case.
Nov 22, 2016Guru - Experienced User
Perhaps you are using "share" security? That was deprecated a while ago, now the recommended mode is "user" security. There is some advice on migrating here: http://readynas.sphardy.com/2010/09/how-to-migrate-to-user-security-mode_4917.html
Though if you just have it fully open it shouldn't matter.
