brooky
Sep 08, 2011Aspirant
iTunes Library (SLOW)
Hi Folks, I copied my itunes folder over to a music directory on the ReadyNAS. I then changed the pereferenced on iTunes to point to: /Volumes/media/Music/iTunes It's soooooooo slooow. What ...
GJSchaller
Sep 08, 2011Guide
I did what Singularity did - made an iTunes share, and then within iTunes, pointed it to be my Library. Once that was done, I went into the Library options and did a "Consolidate Library", which copied all of the media to the new share.
Note that this will leave the library index file on your computer, and if you're disconnected from your NAS for some reason (such as on a laptop, but away from home), you can still download files - iTunes will store them locally, and you just need to re-Consolidate when you're connected again.
