Avorill
Nov 18, 2012Aspirant
iTunes. NV+ V2 4bay's
Hi all. I just got my first NAS. I read on the Netgear website about the device before I both it and noted it had a iTunes Server but I can't find how to turn the iTunes server on the NAS. Dose th...
axg20202
Nov 23, 2012Aspirant
Its not supported by Netgear as its not an official feature, so I doubt they will give you a step-by-step. I managed to work it out for myself, so I'm sure you could using the above. You can't do an harm using PuTTy to get used to browsing the file structure of the NAS. Once you work that out and how to copy a file from A to B, the rest is easy.
