Avorill
Nov 18, 2012Aspirant
iTunes. NV+ V2 4bay's
Hi all. I just got my first NAS. I read on the Netgear website about the device before I both it and noted it had a iTunes Server but I can't find how to turn the iTunes server on the NAS. Dose th...
mdgm-ntgr
Nov 23, 2012NETGEAR Employee Retired
No, no, no. Don't use Notepad as that will corrupt the formatting of the file. Use Notepad++ if anything. You could just use the "vi" command to edit the file via the command line (could look up this command's MAN page for instructions on how to use it).
It is a good idea to make a backup of the file before editing it though.
It's possible you might need to edit the firefly config depending on what its contents are too.
