Avorill
Nov 18, 2012Aspirant
iTunes. NV+ V2 4bay's
Hi all. I just got my first NAS. I read on the Netgear website about the device before I both it and noted it had a iTunes Server but I can't find how to turn the iTunes server on the NAS. Dose th...
johntclinton
Jan 29, 2013Aspirant
mdgm wrote: The file you want to edit is /etc/default/services
It should be full of lines showing whether services are enabled or disabled.
Thanks, mgdm.
Still struggling a bit here. When I try to copy that file, I get an error (no such file or directory).
There is a services file in the /etc directory, but this is a long list of port allocations (including 3689 for daap). Is this the file I should be trying to edit (I tend to think not) ?
I can change to the etc directory to list its contents, but I can not change to /etc/default
Thanks,
John
