Avorill
Nov 18, 2012Aspirant
iTunes. NV+ V2 4bay's
Hi all. I just got my first NAS. I read on the Netgear website about the device before I both it and noted it had a iTunes Server but I can't find how to turn the iTunes server on the NAS. Dose th...
Ja5on
Oct 28, 2013Aspirant
Hi folks
I've been following this discussion with great interest (in particular because I have an NV+ v2 and a DUO with the same architecture I think).
I've used the add-on most kindly provided by mdgm to enable the mt-daapd setting in /etc/defaults/services and ssh'd into the box to check it for myself. After restarting the NV+ v2 there was no response to http://my.nas:3689 - so I did a bit of digging and enabled logging in /etc/mt-daapd.conf which shows the following error:
2013-10-28 21:52:56 (4035a000): Error opening db: No backend database support for type: sqlite
Is this part of the reason it's not showing anywhere? And if so what's a likely solution (if any).
I guess something SQL-y?
I'm looking around this site for guidance on sqlite, but am conscious that I don't want to break it whilst it has a couple TB of media!
[ the relevant part of /etc/mt-daapd.conf are (if not overridden elswhere)
# db_type (required)
# This is what kind of backend database to store the song
# info in. Valid choices are "sqlite" and "sqlite3".
db_type = sqlite
Jason
2013-10-28 21:52:56 (4035a000): Firefly Version svn-1676: Starting with debuglevel 2
2013-10-28 21:52:56 (4035a000): Plugin loaded: rsp/svn-1676
2013-10-28 21:52:56 (4035a000): Plugin loaded: ssc-script/svn-1676
2013-10-28 21:52:56 (4035a000): Plugin loaded: daap/svn-1676
2013-10-28 21:52:56 (4035a000): Starting rendezvous daemon
2013-10-28 21:52:56 (4035a000): Starting signal handler
db_type = sqlite
Jason
