XtheUnknown
Feb 24, 2016Apprentice
iTunes service does not start
When I click to enable the iTunes server on System/Settings/Services, it seems to start briefly (i.e. have green underline), and then stop again. Nothing on the log page to indicate an error.
No problems creating a share called "iTunes", just can't start the service/protocol to access it from a client itunes session.
Using a ReadyNAS104 on 6.4.2...
Any ideas?
Please check if the iTunes service is now working.
Your iTunes service config file was blank so I copied the default config across the re-enabled the iTunes service on the iTunes share.
- JennCNETGEAR Employee Retired
Hello XtheUnknown,
Have you tried on another web browser? Or even enabling another service like ReadyDLNA?
How about reboot then try again?
- XtheUnknownApprentice
Tested using the latest versions of Firefox and IE.
ReadyDLNA is already enabled.
I have rebooted innumerable times.
Any other ideas?
Hello XtheUnknown,
This can be fixed from the backend, I think. Let's see if someone here from the community can do that.
