teddis
Feb 13, 2018Aspirant
iTunes service does not start
Hi, I noted this problem back in June 2017 ( http://tinyurl.com/y9cfqeqh) and saw someone else had the same problem two years ago http://tinyurl.com/y9buxdk4 Can someone PLEASE help me get this w...
teddis
Here are my logs showing "failed to start"
packages.log:ii forked-daapd 24.2-0.netgear1 armel DAAP/DACP (iTunes) server, support for AirPlay and Roku devices
systemctl-status.log:● forked-daapd.service loaded failed failed DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote
systemd-journal.log:Feb 13 09:11:20 ReadyNAS systemd[1]: Started DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.
systemd-journal.log:Feb 13 09:11:20 ReadyNAS systemd[1]: Stopped DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.
systemd-journal.log:Feb 13 09:11:20 ReadyNAS systemd[1]: Failed to start DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.
systemd-journal.log:Feb 13 09:15:07 ReadyNAS systemd[1]: Started DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.
systemd-journal.log:Feb 13 09:15:08 ReadyNAS systemd[1]: Stopped DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.
systemd-journal.log:Feb 13 09:15:08 ReadyNAS systemd[1]: Started DAAP/DACP (iTunes), RSP and MPD server, supports AirPlay and Remote.
- teddisFeb 13, 2018Aspirant
Here's more from the log:
systemd-journal.log:Feb 13 09:11:20 ReadyNAS forked-daapd[17995]: [FATAL] db: DB init error: trigger update_groups_new_file already exists
systemd-journal.log:Feb 13 09:11:20 ReadyNAS forked-daapd[17995]: [FATAL] db: Could not create tables
systemd-journal.log:Feb 13 09:11:20 ReadyNAS forked-daapd[17995]: [FATAL] main: Database init failed
And here is my forked-daapd.conf file:
general {
# Username
uid = "media"
# Database location
db_path = "/apps/.forked-daapd/songs3.db"
# Available levels: fatal, log, warning, info, debug, spam
loglevel = log
# Admin password for the non-existent web interface
admin_password = "unused"
# Enable/disable IPv6
ipv6 = no
# Library configuration
library {
# Name of the library as displayed by the clients
# %h: hostname, %v: version
name = "ReadyNAS"
# TCP port to listen on. Default port is 3689 (daap)
port = 3689
# Password for the library. Optional.
#password = ""
# Directories to index
directories = { "/data/media" }
# Directories containing compilations
# Matches anywhere in the path (not a regexp, though)
# compilations = { "/compilations/" }
# Should iTunes metadata override ours?
# itunes_overrides = true
# Formats: mp4a, mp4v, mpeg, alac, flac, mpc, ogg, wma, wmal, wmav, aif, wav
# Formats that should never be transcoded
# no_transcode = { "alac", "mp4a" }
# Formats that should always be transcoded
# force_transcode = { "ogg", "flac" }
