niallryan
Jan 05, 2020Guide
iTunes Streaming - not working with ReadyNas Ultra 6
Hi there, Been a while since I was on but that speaks volumes (pardon the pun) on how good ReadyNas is. But now I have an issue which is getting to my and having me pull what hair I have left ou...
Sandshark
Jan 05, 2020Sensei
"Current OS" is not really very descriptive. Is your Ultra6 on the latest OS4.2.x intended for it, or have you updated it to OS6?
I don't use iTunes, but I can imagine anything for 4.2.x is getting a bit long in the tooth. Upgrading to OS6, if you have not already done so, is likely your best plan.
- niallryanJan 05, 2020Guide
Hi Sandshark,
Many thanks for the reply and my apologies. Current OS is the current one overall (6.10.2)
Thanks
- niallryanJan 07, 2020Guide
Hi SandShark,
Any ideas ? Also, anything in realtion to the RN104 not staying connected as a network drive on my Mac Mini ? Keeps dropping off after a few minutes.
TIA
NJP
- SandsharkJan 07, 2020Sensei
I'm not an iTunes user, so the upgrade to OS6 was the only advice I could give there, and you's already done it.
I know some NAS had overheating issues with their NIC, but I don't recall the 104 being one of them. When it's offline, is it just Samba, or does RAIDar also lose it? And what are the statuses of the connection LEDs on the NAS and router/switch at that point?
