DayHawk96's avatar
DayHawk96
Nighthawk ax6000 not working with xfinity stream
Upgraded to the nighthawk cax80 to get rid of the rented router I had, now xfinity stream won't work over this router/modem?
They have xfinity on the box and is listed on their suggested site. Super frustrating...
  • The problem was netgear armor. It was blocking the stream from xfinity for whatever reason.
    Hopefully they can fix that feature because I liked the security...
