komm_it
Aug 29, 2018Guide
JBOD (Single)-function (2 HDDs as 2 independent drives) on USB
 Hello,
 I'm trying to set up a JBOD box  (IcyBox IB-3662U3) with 2 HDD as 2 independent drives on a one of the USB port.
 The RN31600 only recognize 1 HDD. Windows or MacOS recognize and mount both...
mdgm-ntgr
Aug 29, 2018NETGEAR Employee Retired
I don't think so.
Btw if you download the logs what is the date in bios_ver.log?
- komm_itAug 30, 2018Guide
Ok thank you.
Could a newer bios do the job?
/sys/class/dmi/id/bios_date
11/06/2013- mdgm-ntgrAug 30, 2018NETGEAR Employee Retired
No. In any case you already have the latest BIOS for your ReadyNAS installed.
What the latest BIOS does have is a USB3 F/W update.
Well, actually, after having created sharepoints on both drive separatly (only one drive physically connected at a time) and connecting both drives again, I can see and access (r/w) both sharepoints via SMB and FTP…But the system only recognises 1 physical USB HDD
Could this set-up be reliable and what could be the possible drawbacks of such a set-up?
