komm_it
Aug 29, 2018Guide
JBOD (Single)-function (2 HDDs as 2 independent drives) on USB
Hello,
I'm trying to set up a JBOD box (IcyBox IB-3662U3) with 2 HDD as 2 independent drives on a one of the USB port.
The RN31600 only recognize 1 HDD. Windows or MacOS recognize and mount both...
mdgm-ntgr
Aug 29, 2018NETGEAR Employee Retired
I don't think so.
Btw if you download the logs what is the date in bios_ver.log?
komm_it
Aug 30, 2018Guide
Ok thank you.
Could a newer bios do the job?
/sys/class/dmi/id/bios_date
11/06/2013
- mdgm-ntgrAug 30, 2018NETGEAR Employee Retired
No. In any case you already have the latest BIOS for your ReadyNAS installed.
What the latest BIOS does have is a USB3 F/W update.
- komm_itAug 30, 2018Guide
Well, actually, after having created sharepoints on both drive separatly (only one drive physically connected at a time) and connecting both drives again, I can see and access (r/w) both sharepoints via SMB and FTP…But the system only recognises 1 physical USB HDD
Could this set-up be reliable and what could be the possible drawbacks of such a set-up?
- StephenBAug 30, 2018Guru - Experienced User
Personally, I think it is better to set up the NAS with enough capacity to hold your data on internal drives.
If the drives are disconnected for some reason (or if the NAS has the power cut) you might end up with "dirty" volumes (due to lost cached writes). While this can also happen with internal volumes, the risk is higher with external drives. I suggest protecting the IcyBox and the NAS with a UPS (a single UPS protecting both devices, with the NAS monitoring the UPS over USB).
If you don't have any linux systems (apart from the NAS) you might try installing R-linux for Windows, and see if it can read the volumes (with the Icybox connected to a PC). https://www.r-studio.com/free-linux-recovery/
