komm_it
Aug 29, 2018Guide
JBOD (Single)-function (2 HDDs as 2 independent drives) on USB
Hello,
I'm trying to set up a JBOD box (IcyBox IB-3662U3) with 2 HDD as 2 independent drives on a one of the USB port.
The RN31600 only recognize 1 HDD. Windows or MacOS recognize and mount both...
komm_it
Aug 30, 2018Guide
Thanks, I understand the risk with power cut and a UPS is definitely a good advice.
We have some free space on the NAS (X-RAID2) but all slots are used and the space left won't cover the need for this particular project
Those external drives are supposed to collect raw pictures from a timelaps system via FTP.
This system will be running over 3 years, accumulating a really large amount of data (raw pict) from 4 differents cameras.
We'd like to use both USB3 port with 4 x 12TB HDD (1 HDD per camera)
The idea by using a USB external JBOD system instead of internal NAS is to be able to easily replace the HDD when they are running out of space.
A JBOD system makes the whole set-up much more flexible. HDD can be stored and used directly on workstations for editing.
Well, perhaps a new 4 drives NAS set up as JBOD is actually a better / safer solution…
Thanks again for your advice
