sp00led
Feb 07, 2013Aspirant
Joined to core DC. Can't add users from other domains
I've got a ReadyNAS 3200 I just defaulted to rebuild a 16TB arrary. Decided to use domain authentication this go around. I successfully joined it and anyone built in my core domain works as expected. ...
kossboss
Feb 08, 2013Guide
Did you set the forest to be shared in your domain settings on the readynas this is under the security settings. Also make sure the Time zone is set to the correct time zone in Clock tab. Back to security settings, Also make sure your Domain type is set to ADS. Make sure your NTP points to the IP address instead of hostname or domain name. Make sure your DNS points at your DC also using IP. Also make sure that when your in domain mode that you set your permissions using the your Domain controller with the admin account, set sharing on all folders to everyone - or just dont touch the sharing tab, just play around with the security tab. Remember the more specific rules win.
