bettley_smith's avatar
Sep 11, 2010
Jumbo Frames Issue
Running readynas Pro, netgear GS716T ports configured for framesize 9216, PC also running jumbo frames but when I look at the diagnostic logs i see this:
Disks
Passed diagnostics.
Memory
Passed diagnostics.
Network
Passed diagnostics.
Performance
* Jumbo frames are disabled on interface 1. If both your switch and clients support jumbo frames, you can enhance your write performance by enabling jumbo frames on this interface.
* Jumbo frames are disabled on interface 2. If both your switch and clients support jumbo frames, you can enhance your write performance by enabling jumbo frames on this interface.
Volume
Passed diagnostics.
So am I running with Jumbo frames or not?
Thanks Mark
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Have you made sure you've enabled Jumbo Frames under Network > Interfaces > Performance Settings in Frontview? You'll need to do this for each NIC.
    mdgm-ntgr
    When did you download the logs? Could you try downloading them again and checking diagnostics.log?
  • @mgdm
    I notice that you are using a Duo V2 !
    Is there any way to deal with the Jumbo Frames issue on this device when using dashboard 1.0.0.168 ?
    I have just recently purchased a DuoV2 and using it via a 2wire router modem I am having difficulty transferring bulk files without getting a false "device full" message.
    SB
    mdgm-ntgr
    Sure am (along with some other ReadyNAS models).
    You don't need to enable Jumbo Frames on your devices, in fact it's not an option in the dashboard. Jumbo Frames isn't enabled on the Duo v2
    So is Jumbo Frames enabled on your other devices? If not, then no Jumbo Frames isn't the problem. If you have, you could try SSHing in and editing /etc/network/interfaces, but this would be unsupported and the changes might not stick.
    Btw this thread is very old. Please in future open a new thread rather than reviving an old thread. If necessary say something I like "I think my issue is like the one mentioned here: <INSERT URL>"
    edit: Don't edit /etc/network/interfaces. Edit /etc/default/services. There is a line you can add that should enable jumbo frames: "JUMBO_FRAMES_eth0=0" (no quotes). An OS re-install should disable Jumbo Frames if this doesn't work.
ProSupport for Business
