hengy1
Oct 18, 2014Tutor
Jumbo Frames Packet needs to be fragmented
I'm trying to set up jumbo frames. The Readynas NV is set to autonegotiation with an MTU size of 7936. I'm using a terminal and trying to access it to determine best MTU size for transmission. The hig...
grunnsat
Oct 19, 2014Aspirant
That will be a problem with your switch, or the switch in you router. Not every switch or router supports jumbo packets.
- Aug 04, 2024Retired_Member
