amarschilok
Mar 20, 2019Aspirant
Kernel Plus usage
I've been searching for a while, and I just can not find any reference documentation for the Kernel Plus app on my ReadyNAS 102. All I can find are vague descriptions of "advanced CLI network options...
- Retired_MemberMar 21, 2019
Hi amarschilok , welcome to the club. If you like you could comment/upvote on the idea behind this link to document your frustration and nudge the developers into the intended direction. Kind regards
Retired_Member
Mar 21, 2019Hi amarschilok , welcome to the club. If you like you could comment/upvote on the idea behind this link to document your frustration and nudge the developers into the intended direction. Kind regards
- StephenBMar 21, 2019Guru - Experienced User
FWIW, you won't need this app if you are using ssh to examine file permissions, copy/rename/delete files, or examine system status and logs.
So I don't think you'll miss it if you pass on the install. On the other hand, it does no harm to install it.
- amarschilokMar 28, 2019Aspirant
I'm mainly interested in Kernel Plus for the promised "advanced networking" features. I'm getting abysmal throughput performance, and I'd like to at least be able to try to fix it.
- StephenBMar 29, 2019Guru - Experienced User
Kernel Plus just installs some additional packages that might be needed for some other installs. It doesn't add any new functionality to the web ui.
Can you provide more details on your throughput? Have you checked disk health and the network stats in the log zip file?
