amarschilok
Mar 20, 2019Aspirant
Kernel Plus usage
I've been searching for a while, and I just can not find any reference documentation for the Kernel Plus app on my ReadyNAS 102. All I can find are vague descriptions of "advanced CLI network options...
- Retired_MemberMar 21, 2019
Hi amarschilok , welcome to the club. If you like you could comment/upvote on the idea behind this link to document your frustration and nudge the developers into the intended direction. Kind regards
Retired_Member
Mar 21, 2019Hi amarschilok , welcome to the club. If you like you could comment/upvote on the idea behind this link to document your frustration and nudge the developers into the intended direction. Kind regards
Mar 21, 2019Guru - Experienced User
FWIW, you won't need this app if you are using ssh to examine file permissions, copy/rename/delete files, or examine system status and logs.
So I don't think you'll miss it if you pass on the install. On the other hand, it does no harm to install it.
